DeathBlade
- Joined
- Oct 18, 2008
- Messages
- 111
Well I'm getting rid of my MPIII and going to RC drive the plan it is to use two 80-100's I'm going to press out the origninal drive shaft and put both motors on one chromoly shaft. I will run that into a right angle gearbox (here is were I need some help) on the output of the gearbox I'm going to put a freewheell adapter and put on a white 16T freewheel that will turn either a 32T-48T- 48T or 52T cyclone freewheel crank going to my my stock gears have a 9 speed cassette(11t-34t) in the back. Powering this will be my 12s4p lipo pack of turnigys at 20ah controller is also need to be spec'ed.
I live in a very hilly area of pittsburgh, and I'm overweight (230lbs) and have a XTS downhill frame that weighs a ton(45-60lbs)
Speed isn't a very high concern more for hill climbing capability. ie geared for 15-20mph middle of the cassette
Now for the gearboxes I have my eye on
bayside RS60 gearbox its a 5:1 gear box
second is a GAM Gear DS-TB-055-005G 5:1 ratio
Last is a Alpha SK-100 at 3:1 (this might be to low of a gearing)
So which gearbox do you guys think is the best bet for two 80-100's?
Some of my goofy math.
48v * 130kv = 6240rpm
6240 / 5 = 1248rpm
(6240 / 3 = 2080rpm)
48t / 16t = 3
(52t / 16t = 3.25)
1248 / 3 = 416
6240 / 5 = 1248rpm
48t / 16t = 3
(52t / 16t = 3.25)
1248 / 3 = 416
