Mike_Kelly
1 W
I am converting two bikes and bought one TSDZ2B kit with OSF pre-flashed and the included 860c pre-flashed and one kit stock...by mistake.
So I finish installing the OSF kit on my bike and it is fantastic. In comparision to my M820 bike I find it applies assist more naturally. With the M82o if you are going up a step incline you have to up your cadence to get assistance. It you are pedaling relatively slowly it does not give you much assistance. But the TSDZ2B-OSF does a great job. If I kind of get out of the saddle without gearing down, still pedaling slowly with more torque, it adds assistance very naturally. I really like it better than my M820 bike.
I then finished my wife's bike with the stock firmware and it was awful. She hated it. She had to set assist way up to get any help at all.
I had read how much of an improvement the OSF firmware was for the TSDZ2 series. But have a hard time believing it could be this different.
So I went about trying to flash OSF on her bike. I had a really difficult time with the available documentation. Which is not surprising in my experience with open source projects. For those in the future trying to do this a few notes while it is fresh in my mind.
First the same firmware from emmbrusa works with both the TSDZ2 and the TSDZ2B. There is firmware for the motor, that will be using a specific display, and separate firmware for the display. The original display the V5LCD is different that most newer displays. The V5LCD can not change the parameters of the motor via the display. Hence you have to compile a version of firmware with all the settings you need pre-set. A set is like the motor voltage. There are two basic versions of the TSDZ2B, one for 36v and one for 48v. Once you use the java based configuration utility you save a set of parameters and they are compiled into a special firmware just for you.
On the other hand the 860c display can change the motor parameters via the display menus so there is no need to go through the compiling.
You must use the same version firmware for the display and the motor. NOT the same firmware but a firmware for the display of the same generation as the firmware for the motor. For me at this moment in time it was the motor firmware labeled TSDZ2-v20.1C.5-update-1-860C.hex and display firmware 860C_v20.1C.5-1-bootloader.bin.
To install the motor firmware you use the STM programming windows application that writes to and reads from the microcomputer in the motor,
Next you need to connect another cable commonly called a boost box because it boosts the voltage of the computer usb. Between the display cable that normally connects to the motor not the one that connects to the assist control. They have different connectors so not hard to get it right.
BUT when you plug in your programming cable or boost box to the display I had to turn on the power button on the remote assist handlebar device to get the system to work. The boost box essentially adapts the 5v usb port on your computer to the, in my case 36v, of the ebike battery. It would not power up the display and allow me to transfer the firmware from my computer to the diaplay until I "turned it on". Even tho there was no indication of it being turned on. Then an application provided by the display manufacturer, in my case APT called the APT Burn tools. This is a poorly written app that allows you to load the 860C_v20.1C.5-1-bootloader.bin file and send it to the display.
After you program the display for OSF you must go into the menu (hold - and + and power on the remote) and make the same settings that the java configurator does in the V5LCD method. They can be bewildering. You must get the motor voltage right 36v or 48v. I copied the settings from my pre-configured OSF kit to the newly programmed kit.
It is raining hard here and I am yet to see if this really solves the problems identified by my wife. I sure hope so. As the old proverb wisely states happy wife - happly life.
God I hate windwows
STVD-STM8 ST Visual develop IDE for developing ST7 and STM8 applications.
You need to load usb drivers for the STM programming cable you have to buy or make, thats the CP210xx windows drivers. Plug your cable into the cadence cable coming out of the motor and the other end into your windows computer usb port. IF you don't hear a windows "chime" when you plug in your cable then something is wrong. Worng driver or bad cable. Then you use the STM application to load the TSDZ2-v20.1C.5-update-1-860C.hex file and write it to the motor. In the STM application you have to specify three things. You want to choose left panel STLink, center panel SWIM and right panel STM8S105x6 NOT STM8S105x4. I had to do this many times to get it to work. The motor battery must be on.Next you need to connect another cable commonly called a boost box because it boosts the voltage of the computer usb. Between the display cable that normally connects to the motor not the one that connects to the assist control. They have different connectors so not hard to get it right.
God I hate windwows
