Mike_Kelly
Established
Gathering materials and researching I decided on the TSDZ2B OSF with the 860cc display. But what is confusing is that there appear to be two (or three) versions of the 860c. One is the version made for Bafang with either a UART Higo connector or Canbus connector. Then there is a version touted as being for the TSDZ2B with a different 5 pin connector. It is all black unlike the color coded Bafang style. The ads indicate that it is converted for use with the Tongsheng.
I plan to use brake sensor levers so since the 860c does split out connections for throttle and brake sensors I decided I could use an IT4 cable to split out the throttle, brake and display cables.
My TSDZ2B kit came with a 860c with a Bafang style Higo green color coded display cable. But I received multiple IT4 cables. One Bafang style and one with black connectors.
So the question is are all 860C displays the same with different connectors? If I have an IT4 that connects to the 8 pin TSDZ2B motor connector and has Bafang style color coded ends and an 860C with the same color coded connector will it work with OSF for 860c or must I have all parts made for Tongsheng with an 860C made for the TSDZ2B and a matching IT4 cable? or is there no way to use an IT4 with the 860c to add the brake levers?
THanks
THanks
