9cx88078b8907euorhjl
10 µW
I was told that the controller both the 36v/48v versions are the same 36v 250w + OSF -> 48v?
So I flashed a 36v 250w to 48v 250w using GitHub - emmebrusa/TSDZ2-Smart-EBike-1: TSDZ2 Open Source Firmware adapted to VLCD5-VLCD6-XH18 displays, which worked with the java configurator.
If I don't manage to fix it, it would be amazing if someone had the 48v firmware saved so I could flash it with STVP in the meanwhile.
When I power everything up, the VLCD5 display isn't displaying the correct battery level (1 bar, when it's @80%), throttle not working. My settings are to start up in street mode, in that mode, throttle is enabled unconditionally. So the VLCD5 only had the throttle plugged in. I did not test pedalling yet. But the battery level not showing right is worrying.
Hope someone has been through this before and managed to fix it, as I cannot find anything to help? Perhaps the speed sensors/brake sensors need connected (in settings it's not possible to enable throttle without choosing a brake feature, 3rd image) Here are my settings:
