izeman said:Any idea how I can discharge them at 30a?
amberwolf said:loko upauraslips' disharger projetc with halgoenbulbs
izeman said:I know measured six cells and they are all above 19ah. This is great. Internal resistance is somewhere in the low 10s. Do you think this still OK?
Any idea how I can discharge them at 30a? I calculated resistor for that and came to 0.2 ohm. Can't find any resistor that low with 100w+.
999zip999 said:What size pack are you going to make ?
999zip999 said:ev99saturn 12s4p are these sub- packs for a car ? And yes what is izeman planing to do with his ?
atm i can only discharge at 6a. which gives me high 19ah+. but to test those cells under real live conditions i need 30a load to see sag and how much they will deliver. as i wrote internal resistance is about 5-10 times higher then nominal. so i expect some sag - and now i want to be sure what will happen, or i will have to open a paypal case.dnmun said:why do you have to discharge a cell at 30A?
in case you asked me: 24s1p for an ebike.999zip999 said:What size pack are you going to make ?
I measured connections, not whole battery, 0.6-0.8mOm, read about it in first my build link.izeman said:did you measure resistance of your whole battery?
Signal wires soldered to cotter pins, 10AWG wires soldered to tabs.sendler2112 said:Are the main wires soldered onto a pin also?
thanks. 50mOhm would be a great value.evb said:izeman said:.. I guess 16S battery without BMS is about 40-50mOm, I will measure for you later![]()
izeman said:ordered this now: 100w 0.1ohm. mounted to a cpu heatsink with cooler, this will be a nice 30a load.
http://www.conrad.at/ce/de/product/422894/ATE-Electronics-100-Watt-Hochlast-Drahtwiderstand-axial-bedrahtet-Hochlast-01-100-W-5-
megacycle said:izeman said:ordered this now: 100w 0.1ohm. mounted to a cpu heatsink with cooler, this will be a nice 30a load.
Light globes and resistors they've all got their temp coefficients to take into account.
They warm up resistance changes, if your monitoring your current it will alter with the resistor temperature which will be affected by an Isqd driven by a dropping terminal voltage
I think your resistor spec is here http://www.brose-elektronik.de/english/bricks/ATE_WI_RB_eng.html.
Basically you'll have to log a varying current for Ah, for accurate.
Have fun and luck, hope your cells are good.
I'll look how the pro's measure the Ah, I've seen the tests and results before just can't remember how :?
I had some tests an A123 cell with this (a set of resistors), 120A is ok for discharge 20Ah cellmegacycle said:izeman said:ordered this now: 100w 0.1ohm. mounted to a cpu heatsink with cooler, this will be a nice 30a load.
