wb9k
major said:wb9k said:Well, if I'm confused at this point, so are the company's assembly specs and every engineer in the building responsible for them.
This leads me to believe there is still confusion.
wb9k said:OK, well mech stuff is not my forte. Apparently the verbiage comes from the air pressure driving the stack compressor, not the actual measurement of psi in the stack. My bad. So what's the proper verbiage...10 lbs of end-to-end pressure?
_10 lbs of end-to-end pressure?_ You say. 10 lbs is a measure of force, not pressure. Pressure is measured in pounds per square inch. Force is measured in pounds. See the difference?
Bigmoose helped clarify this for me a couple days ago. 10 lbs of end to end pressure was a misstatement by me. I have since spoken to the engineer responsible for this aspect and seen the spec. PSI was correct all along, I just didn't understand how much external pressure that equated to. I'm confident I'm stating things correctly now, and the verbiage of our specs says the same.
