wb9k
whatever said:that doesn't make any sense, as mentioned all the a123 20ahr cells that I can find on the net from usa/korea etc have same format, same format as I've given from the cells I have. All numbers are included, you seemed confused.wbk9 wrote:
I see the problem now....you didn't give the number that contains the date code information
Have you got any pictures showing kapton tape under the aluminium tabs?
My bad, you did give that portion of the number. However, the Korean format is different from what is used today. Looking at a USA cell in one of your links, you'll see a number printed between the tabs at the very top of the cell: SHD11E2201963. This is reproduced in the main body of text that is found down a bit and to the left. On your cell, this appears to correspond to the "vgj5045b0149" portion of the text. This does not contain any date code info that I can discern. I understand this looks like it's the same format, but it isn't. This is one more reason I think this was from an experimental build--oddball codes probably intended to prevent the escape of the cell into production material. I don't have any pics to share with Kapton on both electrodes, but I can assure you I've torn down dozens of cells by now--including several Korean cells--and they ALWAYS have it. You have a cell there that is at least a few years old, and unusual in many regards from anything I have worked with. That doesn't mean it won't work, but it does raise questions about the origin of the cell.
