jonescg
In the most general terms, you can't solder aluminium. You can make a mess which doesn't move when you tug on the wire, but it's only being held there by friction.
There are means to bond aluminium with more aluminium, but the process will probably ruin your cell given the heat you need to pump into it.
Spot-welding copper to aluminium is currently the only way to do it. Or just clamp it nice and tight like others have.
