docnjoj
1 GW
Way to go, agniusm! This would allow soldering balance leads directly to the blocks. Definitely not as elegant as your connectors and traces but could save on costs of making the board, perhaps?
otherDoc
otherDoc
docnjoj, this is for the end terminals, design remains the same . My concirn was end blocks 10mm. These were heating up while pulling lots of current. Copper copes with that easy.
I got more than 9 mins and perhaps close of what you calculated.
deVries said:I got more than 9 mins and perhaps close of what you calculated.
If you check your video you did not apply any load until 41 seconds after you started the timer. I'm certain you consumed more than 16Ah, when you had already stopped the loading at just before 8:58. So, 8:17 was your actual run time for loading. Your starting cell voltages were nominal at 3.29v, so you probably didn't run but many seconds before you remembered to start the timer again. Say you forgot for 45 seconds, though you probably caught the mistake within seconds w/video on, then that load time beyond 16Ah was only about 9 minutes total (8:17 + time to catch timer mistake) vs what should have been 12:48.
That's why I'm really curious for you to *please* just do one more test anywhere between 30A-40A. I think that is more the normal range of use for eBikes, and maybe the battery will run more efficiently in this amp range. Please video one more new test in that 30-40 amp range, and remember to start the timer when the load begins with temp probes ready and battery cells at 3.3v nominal.
You are our great A123 scientist researcher too. We seriously need your science experiments. You have the perfect test equipment & setup. You're great at video, and you are becoming our famous ES documentary actor.
Maybe you're too busy to do the test today, :lol: but you could do it within a couple of weeks or so...
Thanks. Oh, and what's interesting about your test is the cell-pouch temp peaked at 51c after 9 minutes at 75A, so the cells are increasing in temp more so than your end terminals at end of discharge. I wonder if your copper end terminals will really decrease the IR of the battery? You need to do another load test at 75A to see how much more time you can run the battery with the copper terminal vs aluminum. Since your battery cell-walls are getting so warm, I wonder if the copper terminals will really help lower the IR of the battery?
999zip999 said:Agniusm go see you post the pic's of the taps as the holes being off dosen't matter.
ah, ok, no problem999zip999 said:Sorry I was triing to say thanks for posting the pic's.
deVries said:That's why I'm really curious for you to *please* just do one more test anywhere between 30A-40A. I think that is more the normal range of use for eBikes, and maybe the battery will run more efficiently in this amp range. Please video one more new test in that 30-40 amp range, and remember to start the timer when the load begins with temp probes ready and battery cells at 3.3v nominal.
jimw1960 said:If I may add. I am pretty sure the 20Ah ratings are for 1C discharge. When I tested some of these cells a year ago, I was getting something like 19.6Ah at 1C. It does not sound suprising that capacity drops to the 16-17Ah range at nearly 4C discharge. Also, 51 C is really not that hot (123 F for us yanks). It can get that hot on a sunny summer day in Arizona.
deVries said:If you read carefully my previous post, see quote below, I am only asking for just ONE more test anywhere you choose between 30A-40A.
Did you video your 150A test w/copper? What were the temps at end of discharge terminal vs cell-wall pouch?
Thanks.![]()
Aluminium over copper??? perhaps vice verse? Aluminium is 60% conductivity of copper and that is with certain alloys like 1xxx series some 6xxx series and they are most soft which is no good for threading.megacycle said:Hey just made me think, aluminium over copper might help for blocks pulling big amps.
megacycle said:Be interesting to know the Ah per A specs for the pouches.
There looking good at the high C's.
Geez that's hotwhere you are, cook an egg on the pavement.
I live in south australia and it gets hot here book never reaches 50 degC in the metro areas.
Ive worked out in the 'bush'on mining jobs and it gets that hot and even hotter than 50 degC.
And it's a unbearable, it's like being in a sauna, when you are outside.
Yeh but 50degC wouldnt be too hot for pouch.
Will carry on looking around see if i can any info on that.megacycle said:Be interesting to know the Ah per A specs for the pouches.
Yeh meant copper onto tab/s, high conductivity, high thermal sink.agniusm said:Aluminium over copper??? perhaps vice verse? Aluminium is 60% conductivity of copper and that is with certain alloys like 1xxx series some 6xxx series and they are most soft which is no good for threading.megacycle said:Hey just made me think, aluminium over copper might help for blocks pulling big amps.
I ended up splitting the pack to 2x6S kits from agniusm and it is working fine. I just need to make the hard case for the outside and finish mounting the JST connector that I had to use when I messed up the traces (my fault completely)! The pack will power one of our trikes. No BMS but LVC from kfong and Hyperion balance charge for HVCice_robin said:docnjoj said:I am interested in 12S configuration please. Thanks
otherDoc
12S battery pack?where do you use it for ?
maybe we can talk alone by MSN?
I didn't realize guys could do that in OZ. Wow!megacycle said:Yeh meant copper onto tab/s, high conductivity, high thermal sink.agniusm said:Aluminium over copper??? perhaps vice verse? Aluminium is 60% conductivity of copper and that is with certain alloys like 1xxx series some 6xxx series and they are most soft which is no good for threading.megacycle said:Hey just made me think, aluminium over copper might help for blocks pulling big amps.
Smear of thermal paste and aluminium onto that, not for conducting only for higher heat emmisivity :lol: if that's the right word.
The aluminum is a radiator, the copper is the electrical conductor and heat sink.![]()
Explaining that's like giving birth :x![]()
