Thanks to wb9k, I've split the pdf into its 8 sections which can be accessed separately. The internal hyperlinks will obviously not work.wb9k said:I have a care and feeding guide for A123 cells that I can share, but the file is too large to post here, about 15 MB--and that's in pdf format. Any work around for that?
dnmun said:all other sources of information on lifepo4 chemistry indicate that full charged is 3.65v and fully discharged is 2.1V but this document uses 3.6V as fully charged and 2.5V as fully discharged. i know there is very little difference but is there a reason they used these numbers?
is this because it is not a technical document but kinda like a manual for people to read in their safety classes? or does A123 cathodic material behave differently from the other forms of lifepo4? is there a real risk if the cell is charged above 3.7V? has that risk been documented?
dnmun said:i lot of the literature is incorrect if this is true. i have seen more than a few different BMSs that did not even allow the cell to drop to 3.60V before turning the charge back on again after it had shut off at the 3.9V mark. many of them oscillate between the 3.9v and 3.8V reset voltage.
i just wondered if this is specific to A123.
999zip999 said:My A123 20ah seam be be full at around 3.45v and between 3.45v to 3.59v it is off the the races as the voltage goes up so fast. So there can't be to much energy of there. Do bms's need the be set so high for the A123 20ah format cell ?
dnmun said:it does appear that all the lifepo4 BMS use the 3.60V as the balancing voltage. all the ping packs were charging to 58.4V too and they lasted years and years.
it would help a lot if there were some documentation to understand why this is so far off from the literature. also i wonder if this is also the case with the lipo and that the charging in excess of full charge at 4.2V is harmful too. this is something everyone talks about but there has never been any references to the literature where it was shown that charging to full voltage is deleterious.
Spacey said:The problem with an unbalanced pack is that the cells that are NOT out of balance tend to get held at 3.8 to 3.9v by the BMS until the rest of the pack catches up and each cell is held at 3.65v.
With a 20Ah pack the minimal 40ma balancing power of your average crappy BMS is going to take a LONG time holding the high cells at over 3.8v.
But I do have packs that have been left on the charger for over 2 years now (Headway packs) and still hold full AH discharge as they did when new. The BMS holds each 12S 1P pack at 43.8V which means each cell is at 3.65v permanently. Why do I do this? Because leaving them off the charger for days when not used causes the packs to go out of balance which would mean when charging the pack again some of the cells hit above 3.8v whilst the pack is balanced.
Lesser of the two evils.
Maybe I should set the charger to 42.96v which would be 3.58v a cell. Would this compromise the BMS at all?
torqueon said:End of charge, that is what your talking about right ? I have found that you can not slam the cells at 10 or 5 amps until they hit 3.65 volts, (headways cells) and call theme charged. Not so according to my crude load testing one cell at at time, tedious as hell ( don't ask ) 80% charged at best. Hold them at 3.65 volt until amps drop to .100 amp as specified and all deliver as expected
I read lot about HVC and LVC, but do not see much about HVC to end of charge ?? I think this is a real cause of imbalance of packs that I read about and experience my self. What do you think.
Wish I could post that bitching E bike! My passion for this is storng!!
Pete
dnmun said:here is another instructive document from a worthy at SAFT:
http://www.battcon.com/PapersFinal2008/McDowallPaper2008PROOF_9.pdf
from reading about how damaging is the high rate of charge at final voltage when the cell voltage has reached this 3.6V level and the current is still high as it would be with a high current balancing charger then the plating could be significant.
with the bulk charging using a BMS that i am familiar with the current tapering off dramatically as the cell voltage approaches full charge so that the current during this final phase where balancing is occurring is very small (60mA/20Ah=3E-3 C) in comparison to the current that the balancing chargers can still push at this top voltage.
maybe it would be good to have the balance chargers or the power supply type chargers to be able to taper the current off dramatically too, just like with the bulk chargers in order to reduce this plating effect which i am now totally conscious of. i kinda understood that high rate charging and charging at low temperatures was damaging but did not understand how.
before i started reading this stuff, i thought there was not a residual effect of the higher final voltages, mainly because there was no evident damage. because the shunt balancing current is so low that it may not have as much effect as the higher currents during charging that the balancing chargers can produce.
also i had always assumed that any time the cell dropped to 2V under load it was toast. but it does seem that the cell will rebound to a much higher voltage as the free mobile lithium ions finally make it to the electrode and soaked up in the cathodic matrix. so that was why they did not all die when i over discharged them to 1.67V. it seems the trick is to get the over discharged cell back on the charger immediately.
