A2B Octive/Metro purchase?
robbiesd said:
Would you say this is about normal range for the battery?
I loosened the shock nut to no tension when parked, that seemed to eliminate the hop but the spring rattles a bit now when going over a bump as it's unloaded.
Robbie
That sounds about right to me for a used & standard rear pack.. but mine was 'dead on arrival', so I never got a chance to experience/test it before rebuilding.
(Lots of info elswhere here tho. ;)
Some people have fitted a larger crank-chainwheel too, thereby raising the gearing to the point where human legs can actually contribute more useful power to the rear wheel at speed. ;)
OK.. play around with your spring tension a bit more then.. maybe tighten it so there is a little tension when parked.. that might then eliminate both the rattle AND the hop?
Enjoy anyway!
spinningmagnets said:
There are lots of them out there [for sale] if you look long enough
Fechter, if I swapped-in some good street tires, what is the fastest top speed for a frame like this? 30-MPH perhaps?
I'm occasionally doing 30-MPH on a beach cruiser frame (yikes!)
Mine does 35 on a slight downhill. Seems very stable at that speed. It's a very heavy bike so it does well at higher speeds and the brakes are adequate.
No worries Audisport09 - a pleasure to share!
Yes.. you clearly have the general 'picture' now. :)
Regarding paralleling balance leads, my thoughts at the time were twofold:
1). Available space was getting very tight in there.. literally down to millimeters!
2). Factory Li-po battery-batch matching-standards are now chemically really very high (even in China - and owing largely to the 'exploding laptop/phone' era!).
So I concluded that if any one of the x4 cells being parallel-balanced really started to collapse, I would still receive an adequate indication from the charger-monitoring of this - and abiding by the golden rule to never walk away whilst your Li-po's are charging, thus also pre-empt/avoid any terminally serious issue!
For similar reasons, I also never 'rapid-charge' the cells and also always balance-charge - and they have remained stoically within .01v of each other.
A 'compromise' of sorts yes, but I'm very happy & satisfied with it - so far.
Range/performance also remain good.
Maybe you could try contacting Turnigy/Zippy/Multistar etc directly, regarding their present range/catalogue of available high capacity Li-po packs?
Those perfectly (A2B frame) sized Multistars were on 'special' at Hobbyking at the time, so I just went for it - & adapted everything else to suit! ;)
Good luck, continue to enjoy your A2B ~ & please let us know how you go anyway.
Jeez, steer clear is a little bit strong. Yes out of the box, they may not be the best bike in the world, OP said he is looking for a project bike...I'm a roadie as well, the metro is a really nice change of pace, I ride it faster than my road bike thats for sure. Each to their own indeed. Although on second thought, if they have no batteries 1500 has a little steep. Were you looking to buy both for yourself and someone else?
E-Glider, thank you, pictures paint a thousand words. I'm a newbie to lipos but I think I understand now. Didn't know you could palleral balance leads like that. In the event of a cell death, an issue could arise. Maybe some sort of 24 pin connector would be better? I have a 12s charger so I don't think I would need a relay in that setup. But 12s isn't enough :) I only do short rides. Shame about the multistar. So I need 3 high cap lipo's in series with a relay on the third and 3 ports for balance? If I could find 2 high capacity 10s it would make wiring so much easier. Trouble is the highest on hobby king is only 4.5amh.
Hi Audisport09,
Well after 3 years of sitting (both self & bike!), I charged up the A2B Li-Po packs today and found that they had 'stored' flawlessly and have remained stable & balanced cell-wise. :)
Attaching a quick screenshot from the 'ChargeMaster' software that came with the charger.
I went on to charge both front & rear packs to around 80% and look forward to a sunny Autumn day ride here tomorrow.
~ Also fitted a basic 'Sunding' bicycle Odometer/Speedo device recently, so should be able to update with some range figures to suit. ;)
Did you end up trying out the Li-Po possibilities at all?
Enjoy anyway!
