Carmageddon
- Joined
- Sep 14, 2012
- Messages
- 26
Hello!
I have a bike with very bad and weak rear brake (which requires adjustment all the time, and rubs against the rim (very hard to adjust it not to, and still be efficient at braking).
Front wheel is simple Disc brake with wire, but also requires adjustment once in 1-2 months.
Here are pictures of the rear engine area:
I have been recommended to start with this:
http://www.aliexpress.com/item/MTB-Disc-brake-flange-disc-tray-adapter-screw-thread-switch-disk-disc-tray-refires-disc-brake/32312668990.html
Then adding this on top of it:
http://www.classic-cycle.de/en/Brake/Brake-Disc-Rotor-160-mm-with-fixing-screws.html?cur=1&lang=1
Instead of this, can I order this cheaper part? will it fit?
http://www.aliexpress.com/item/Brand-New-AVID-HS1-Brake-Rotors-160mm-or-180mm-6-inches-Disc-2PCS-12-Blots-BB5/32278258472.html?spm=2114.01020208.3.1.qoyFMg&ws_ab_test=searchweb201556_9_71_72_73_74_75,searchweb201644_5,searchweb201560_9
Now the real problem starts:
The guy who helped me with those recommendations - I met him in the train, and suddenly he almost missed his exit so I didnt get his phone number, so I dont know what to do next for the Caliper fitting.
I think I need to find some kind of adapter which I can fit to this frame, and mount the Caliper on it, or find a caliper to which I can bore holes for mounting...
This is where I need your help please... I'd like to at least make a rear wire Disc brake, and if possible without big expenses, preferably Hydraulic Disc brake (the one with oil) so no constant adjustments would be required...
Please assist...
Thanks!
Please assist...
Thanks!
