marce002
Hello
i have this controller with a non hall motor... now works with a single push button ( to full power)... bought like this... want to add this thumb throttle and I need help to wire to controller board....please look in the pics..thanks in advance...
for reference throttle wires
green = battery power max 50v? tested
yellow brown= switch
blk white red = normal throttle connection .8v to 4.1v
do not have idea what this labels in the board means:
HX HV VL ZF VP
only VL is used and 5v is there ....
I do not know how the button is connected is sealed.
DO NOT READ THIS IS IRRELEVANT( for the issue)
for reference only tested:
at 50v 3 leds will be on : FULL HALF EMPTY
when 36v appears in battery power then FULL turns off only 2 remaining..
when 32v or less only red EMPTY ARE ON
HX HV VL ZF VP
