dnmun
1 PW
you cannot balance the pack without using a BMS unless you go use a balancing charger. if this is a new build pack then if the cells are not balanced initially it does take forever for them to balance this way.
you can do like zippy said and use a resistor to drain the current off of the high cells to get them closer but you don't have to remove the BMS to do it. i use big cement power resistors with alligator clips on the leads so i can clip it onto the cell i wanna drain, or group of cells. but you gotta keep the power in mind or the resistor will get too hot.
sometimes i have melted the solder off the connection between the resistor and leads it got so hot.
