RexRoller
I live in the Napa hills and have a 150+ mile commute to get solar appointments 2-3 times per week. I drive 50-60 miles to the appointment and I'm there for an hour which i could also use to charge while I'm there. Then I need 20 miles to get back to my shop to chill and charge more if need be.
A 70 Mile battery with super/fast charge, like the ev stations would be ideal i think.
This is my second build. Trying to get more range, torque, and fast fast charging. I spend hours a day trying to piece this stuff together but one answer leads me to another question. This project has been quite the endless sphere
Steele Micargi Slugo Fat Bike 7 speed disck brakes - ordered!
Cyclone 3kw mid drive - Ordered!
Need to order/build: Fast/Super charging solution.
Here is where I am stuck.
1.Is it possible to make a charger solution that will work for with public ev charging stations?
2. Am i better off learning how to configure the Eaton or Flat or Meanwell psu?
3. Are lipos good for fast charging or should I go with an 18650?
I fell like i am pretty close to understanding this and I am beyond ready to buy and post my build
I am open to any options regardless of cost because I am obsessed with upgrading my commuter. So maybe its cheaper and better to buy a bigger (more)battery and a PSU charger set up or maybe the cost is the same to buy a smaller battery/ies and a kick ass charger set up. Would I get more freedom from a larger battery or a super duper fast charger?
I had considered getting a trailer and a 100lb a123 5.45kwh battery from osh for 1300 i think. Plus a trailer at $150.
I do currently have a 48V 30ah triangle battery that i can use in this mix or sell to upgrade.
I have tried on my own to get to the bottom of this. Some of it'sover my head so thank you all for your help!!!
