MikeSSS
Use is to enjoy riding and looking around, this bike is not for commuting or playing racer.
Motor is Aotema front, direct drive, brushless, sensorless, presently using the stock controller and 36v gel cells. Bike is old mountain bike, set up for upright riding position, battery is on top of rear rack. I'm a bit over 180 lb, terrain has some climbs, the present setup handles the climbs well if I pedal hard in the big ring and mid cog, keeping the speed up on the climbs.
Comfortable speed range for me, on this setup, is up to 16 mph. (My Subaru Robin powered gas bike tops out at 25 and my motorcycle is way faster, I'm not looking for a fast ebike) My energy use is about 16 Wh/mi. Desired range is at least 20 miles. Battery charge plan is mostly to charge to 80% and not discharge down to LVC. Most rides will be in the 4 to 16 mile range.
The batteries I'm looking at are the Lunacycles 48v, 11.5Ah or 13.5Ah, shark case or carbon shark case. The cells will be either the 18650 PF giving 11.5Ah or the 18650 GA that gives 13.5Ah. This pack should mount in the triangle area of the frame, thus leaving the rack open for carrying stuff. Locking on the bike and easy, fast off and on, are important. These packs are 13s, 4p.
Charger will be either the Luna Advanced 48v, that has the option for 100% or 80% charge or a Mean Well HLG 120h-54, plan is to use a watt meter when charging. My understanding is that the charge voltage of the HLG charger can be adjusted down to say 52v to give something like an 80% charge. The charger must not kill the battery when I forget the battery is on charge. This last condition is very important. In the future I'll probably get a Satiator for charging.
OK, advice, comments, opinions?
Thanks,
Mike S. in San Antonio
Thanks,
