Hi,
I've been running 20s of the 8000mAh Zippys and love them so far. I've read that it helps extend the life of the battery to not discharge further than 80% and I'm confused here. Let me explain this and hopefully someone can point out what is probably the obvious...
8000mAh x 80% = 6400mAh. So I watch the cycle analyst and try not to exhaust more than about 6Ah. The numbers vary but what I'm seeing used, and what I'm putting back in, these don't match up. For instance.... I just went for a ride after installing the 3 way switch and wanted to try the 120% speed setting, and I got 44mph
. According to the CA, I used 7Ah but the first battery I just charged took 3220mah. The other 3 will be about the same according to past performance.
This seems like one of those things that should be obvious but I can't figure this out. If we figure each battery expends 3.2Ah, why is the CA telling me I used 7Ah? The 3220mAh I'm putting back into the 8000mAh batteries is only about 40% of their capacity, so could I actually double my usage before charging?
Basically, how do I determine how many Ah per battery I've used if the CA is giving me a totally different figure?
