Hello everybody,
I´m not happy as to how Ampedbikes handled the situation created when I fried my controller. On their website they urge us, customers, to be honest and forthcoming with the description of our problems but they don´t feel bound to act in the same way toward us. Read the following email exchange and form your own opinion about their integrity.
Regards,
Diego Calut
Name of sender: Diego Calut
Email of sender: dmcalut@gmail.com
On 10/17/2011 7:20 AM, Diego Calut wrote:
Hi there,
I installed one of your motors about four months ago and had it working nicely until yesterday when it suddenly stopped. The motor doesn´t respond to the thumb throttle and my CycleAnalist shows that no juice is flowing. The symptoms at the time of failure were a sudden deceleration and a stiffening of the motor. It hasn´t locked up but I had to pedal hard to get out of the way. Lifting the bike off the ground the wheel (it´s a rear 36V 26" rear wheel motor) I can turn it by hand but it is definitely dragging, as if the brake were lightly applied. The free wheel is working OK and I must have rode the bike about 200 miles altogether, using the motor mainly as a help in headwinds and very slight slopes. Again, the failure was sudden with absolutely no warning. Please walk me through the repair! Thanks, Diego.
On Mon, Oct 17, 2011 at 7:39 PM, Support@ampedbikes.com <Support@ampedbikes.com> wrote:
You will need to check all connections to see if there is a loose connnector, besides that it sounds like you may have fried the speed controller which you can buy a new one off of our website. Or you can send it to us in for repair if youd like
Date: Tue, Oct 18, 2011 at 8:41 AM
Subject: Re: Ampedbikes feedback
To: Support@ampedbikes.com
Hi Bud,
Quoting from my original message: "Lifting the bike off the ground the wheel (it´s a rear 36V 26" rear wheel motor) I can turn it by hand but it is definitely dragging, as if the brake were lightly applied." So, can we agree that the problem is basically mechanical and INSIDE the motor and go on from here? Thanks, Diego.
On 10/19/2011 4:36 PM, Diego Calut wrote:
Oops, I was wrong and you are right. I unplugged the phase wires and the wheel turns freely. I measured the resistance between each of the phase wires and the controller's input wires and one of the phases is shorted. By what I've learned thru the net it seems that the phase's FETs have blown, right?
If so the fix would be to replace them and here I have a few questions: Why did they blow up, given that I very seldom use full throttle? Replacing them by the same model won't prevent another blow up, so should I replace all FETs with higher rated ones? By the way, I'm in Argentina so sending the unit back isn't going to work for me.
Regards, Diego
On Fri, Oct 21, 2011 at 4:42 PM, Support@ampedbikes.com <Support@ampedbikes.com> wrote:
Which FETs are you talking about? the motor wires or something else? We can sell you a replacement if youd like
Date: Mon, 24 Oct 2011 09:16:47 -0300
Hi, I´m talking about the FETs inside the controller. One phase (green wire) is shorted to negative input from battery, the other two read 10Kohms. I will buy a replacement but I´m concerned that it may fail within 200 miles, too, not to mention the shipping charges, the custom duties, the paperwork and the fact that I can´t ride the bike. So, in addition to getting a new controller, I´d like to fix the one that got fried with uprated FETs. The ones´ on my controller are marked P75NF758 (or &) CZ OF 7 5 MAR 007. What FETs do you use for repairs?
On Mon, Oct 24, 2011 at 8:53 PM, Danny L. Ray II <support@ampedbikes.com> wrote:
Heya Diego. We don't replace fets. It is not cost effective to replace them.Also you shouldn't burn a controller unless you were running at 72V. The only controllers that have ever been returned are ones that have been connected in reverse polarity to the battery or electric engineers that run it on an oscilloscope or test various internal parts. I did burn one myself when we were first testing the geared motors at 72V. You can avoid burning at 72V if it is well ventilated and it is shunted internally.
Reply |Diego Calut to support
show details Oct 25 (6 days ago)
Hi there,
I thought you replaced fets since your first response was "Or you can send it to us in for repair if youd like". No problem, I´ll source them thru Mouser or DigiKey.
Now, let´s get this straight; I´m not asking for a replacement under warranty or anything like that. I just want to fix my bike and get to ride it again. However, I live in Argentina, a third rate country where everything is made complicated by the government and this means that getting a new controller thru customs is neither easy, nor fast, nor cheap. Just to give you an idea of how bad it is; I bought the kit from you in November 2010, I shipped it from Miami in January 2011, and I finally got it in May 2011. I hope to be luckier with the new controller but my BIG concern is with its reliability.
I´m not about starting a big debate on this issue but my installation has been properly done using Anderson power pole connectors and it has worked satisfactorily until now connected to a 36V 15Ah Ping battery, monitored with a Cycle Analyst. So, this may be a first for you guys; somebody (me) managed to fry a properly connected controller while using it within its ratings. I don´t know that the manufacturing date stamped on the FETs, MAR 007, might be a clue to your supplier using overstock or reject components but I´m concerned that this might happen again to me. As you already know this would be a huge inconvenience and that´s why I´m intent on fixing the old controller too.
Thank you for your patience and would you please advise me as to the shipping costs for a controller and a half-twist throttle to Buenos Aires, Argentina?
Regards, Diego Calut
No response from Ampedbikes as of 10/31/2011
P.S.: I replaced the blown FETs with locally sourced IRF 2807s and the bike is on the road again.
Regards,
Diego Calut
Hi there,
Hi Bud,
Regards, Diego
Hi there,
