clueless987
- Joined
- Sep 19, 2020
- Messages
- 3
Hi all,
A friend was kind enough to give me his old, broken e-bike. It's a foldable "hopper" with a geared, brushless, sensorless hub motor on the front wheel.
Battery and controller were both screwed from water damage, and were only 7S/24V anyway. Being the fool I am, I opted to build a new 14S3P/52V battery for it, purchased a cheap 48V square wave controller with a sensorless mode and wired everything together.
Initially it was absolutely glorious. 8 miles of pure delight. The motor was fairly loud during operation but had loads of power and stayed cool to the touch. Applying throttle at very low speeds just gave dodgy noises and no power, due to the lack of hall sensors, but I was very happy with my creation... Then it broke. :lol:
Below is a video is what happens now during use. At very low throttle levels, the ebike works fine. If I raise the front wheel in the air and apply some throttle, the motor works fine and spins up to a high speed. But if I try and apply more than a very small amount of throttle during use I get an initial ~0.5 second surge of power, then some pretty dodgy noises and no power. Seems like something might be still shorting somewhere as the current rises?
https://youtu.be/RxASG8ohZQM
First thing I found was this https://imgur.com/69fgAqR - spade connectors connecting the phase wires had melted and presumably shorted a little during use. So I cut them out and soldered the wires together, as I should've done in the first place. This didn't fix anything.
So I presumed I'd probably fried some FETs the controller by shorting the phase wires under load. Purchased a new one, wired it in, still no change.
I noticed the 3 pin HiGo connector on the front fork connecting the motor/wheel to the phase wires was getting warm, so I've chopped it out and hard soldered the wire there too. No change.
I've taken the motor apart, and visibly it looks fine to me - though admittedly I'm pretty clueless with electric motors. A couple of pictures are below:
https://imgur.com/l89CslV
https://imgur.com/8DtUFPH
Does anyone have any ideas on next troubleshooting steps? I'd very much rather not replace the motor if possible. It's only a 16" wheel and I've had real difficulty in finding replacements for a reasonable cost.
Thanks in advance for any advice you can offer.
