arber333 said:Well Bas if you will make a hex file for us with 45deg force start, i suggest it would be best to post it on source code thread.
Do you think 45deg start would be best used with hall sensor assisted sensorless? My car will weigh 1.5t so motor will require some torque to move. I like how that sounds "assisted sensorless".
thanks
Arber
arber333 said:Ok i managed to get PUTTY terminal to copy and paste HEX settings! Now i can test various motors and quickly recover settings if something goes wrong.![]()
I noticed though there is no menu to enable 45deg option. What happens if i now choose hall sensors will they be effective at all upwards of mode 2?
Here is the run up of the motor...
https://www.youtube.com/watch?v=r0wZcXttehc
I had to reduce eRPM since the according to him motor is 3pole with 6 magnets in rotor.
https://www.diyelectriccar.com/forums/showthread.php?t=140346&highlight=prius+compressor+inverter
You must not have the sensorless start tuned optimally. I find that with IMP motors like the Leaf and Hyundai I get perfect starts every time. I will post my sensorless settings tomorrow. I can't imagine the Outlander rear transaxle motor will be significantly different.arber333 said:I tried running the Outlander motor with new firmware 2B0. I can see it is more stable just by running it without load.
But when starting from still motor wiggles anyways. I thought it would just turn into one direction.
I will try and connect inverter to Leaf EM61 motor in my car now. I will test it under load.
I will report back when i have results.
arber333 said:How did you tune up your motor for a good start. Which parameters are involved?
Tnx
If that's a legit technical term, I want to know what it means !Lebowski said:wiggle angle
Lebowski said:Did you play with the wiggle angle and frequency in the misc menu ?
Lebowski said:I'd try angle of 10, 20, 30 and 40 degrees, and 5, 10, 15 and 20 Hz for frequency. This makes 16 combinations to try...
arber333 said:Well i tested what you said and i used those values on my Prius compressor
f) wiggle range: 74 deg
g) wiggle rate: 119 Hz
I now get reliable start everytime with some ratcheting of course. But important is that motor wont just conk out if i apply too much throttle. Eventually it will start accelerating. This will be very important for my auto throttle on AC drive.
Thank you.
