64ragtop
Well, FINALLY some results to report!
First ride on "Litheon"
I-Zip 750 chain drive Rider load 310 lbs. Running on one Bosch Litheon "Fat Pack"
3/4 mile first run. (mostly downhill) one led on battery out. battery warm, motor warm
Swapped out battery, so as to not get stranded on the uphill
Return trip. 3/4 mile (mostly uphill) one led on battery out. battery noticably warmer -
motor too hot to keep touching. Speed noticably lower While climbing.
Second battery on charger, ten minutes after finishing ride, charger went immediately to
the fan cooled mode (whatever exactly that means). charger cut off @ 36 minutes.
Battery shows approx 40 volts on funky old Radio Shack Micronta analog voltmeter.
First battery 2 hrs post ride, now @ room temp. showing approx. 35 volts on same analog
voltmeter. Charger did not go immediately to fan cooled mode. Charger fan on @ 10 min, 30 sec.
Charger off @ 36 minutes
Details, impressions and guesses: Well, first, I AM the acid test, at 310 lbs. My scooter is a
two year old I-Zip 750 chain drive, originally loaded with 3X 12 volt 7AH SLA batteries. The stock
controller is marked "36 volt, 25 amp". The scooter has the stock diagnostic 1/2 grip throttle, and
it shows a red led as I get my bulk moving, but as speed increases, the yellow, then the green leds
come on.
The charger cycling I've observed seems to indicate the bms is turning the charger fan on when the
battery exceeds some preset temperature. The plug that I built from scratch taps the positive and
negative contacts of the battery, and has no connection to the terminal in the center of the battery.
Earlier, I measured 40 volts right off the charger, and five volts on that center contact.
I'll post some photos of the battery connector plug that I have built and some ideas I'm working with,
but this thread doesn't seem to be the place for describing the construction. Anyone care to suggest
which forum is appropriate? My first guess is "E-Scooter and Motorcycle Photos & Videos", but if there's
a better place, kindly let me know.
ATB
BC
come on.
ATB
BC
