I will answer on that question by two way: Used and brand new cell
The 18650V :
Used cell (under 100 cycles):
- Max Current use: 15A (10C) max discharge current and not 10A like mentionned on many website.
- Built-in safety against overheating
- Capacity: some website mention 1500-1600 mAh .. i would say 1500 after many test i did at 1C
- The internal resistance is around 50 miliohms
- The recommanded voltage range is 4.2 - 3.0V
Brand new cell:
- Capacity: some website mention 1600 mAh at 1C
- The internal resistance is around 30 miliohms
- The recommanded voltage range is 4.2 - 3.0V.. some will say 2.5V.. but i would not recommand that if used without balancer
The 18650VT :
- Max Current use: 12C (15A)continuous discharge, 20C (26A) short bursts
-Built-in safety against overheating
- Capacity: some website mention 1100-1300mAh .. i would say 1300 after many test i did at 1C
- The internal resistance is around 35 miliohms
Brand new cell:
- Capacity: some website mention 1100 mAh some say 1300 at 1C
- The internal resistance is around 25 miliohms
- The recommanded voltage range is 4.2 - 3.0V.. some will say 2.5V.. but i would not recommand that if used without balancer.
The main difference between the V and the VT is that the VT is made to deliver higher current and higher C than the V.
but doing that sacrifice a little bit of mAh.. around 300mAh.
The internal resistance of the VT is lower than the V
The capacity of the V is higher than the VT
Tn the makita 18V pack, the 1.5Ah use 5s1p of the 18650VT.. so they should say 1.3Ah and not 1.5.. but it's for commercial reason i guess..
For the 3Ah pack, it use the 18650V that have 5s2p of the 1600mAh so this is more like 3.2Ah..
Here is some data i collected over the internet:
HERE IS THE ANSWER FOR YOU D-MAN ABOUT TEST RESULTS the German people seems to appreciate them for the RC use the most information about these konions come from them
http://www.elektromodellflug.de/akku-test/LiIonM-1100.htm
