DaleKramer
BSC057N08NS3 G 80v 100a Infineon Mosfet Failures
I am driving a single fet with a Supertex HT0740 driver.
Here is gate signal into the HT0740 (yellow) and gate signal from the HT0740 (green) with the fet removed from the circuit:
Here is gate signal into the HT0740 (yellow) and out of the HT0740 (green) measured with the scope probe attached directly to the gate on a trace less than 1mm from the gate.
Note, the input to the HT0740 (yellow) now has a 1V/div scale.
In this case the fet does not fail as the load is disconnected from the circuit.
And here is the fet failure when a load is connected.
The load is a motor controller that draws a few hundred milliamps at rest and has about 1000 uf of capacitance to charge when fet closes:
What could be the cause of this failure?
I suspect it has to do with the slow gate turn on time but it appears that the fet is slowing the gate down as the gate signal without the fet is turning on in microseconds.
Thanks,
Dale
Thanks,
Dale
