methods
Legend
So as I get dressed and walk out the door...
We make the following assertion:
1) IF the above circuit analysis turns out to be true
2) AND 240VAC is applied while the P1 Jumper is applied
3) THEN 680V would hypothetically be developed across the cap Stack
4) SO - the caps would be trashed (if not blown apart) and the downstream Mosfets (if not rated) could go shorted. In Addition, the low power transformer tasked with creating 8V would create 16V overheating regulators.
My guess is that the Mosfets are rated well enough (easy to look up - and they come with margin)
My guess is that the caps are heavy duty but ... have failure modes... that may not result in a visible POP
My guess is that the 10K resistor divider would heavily overheat (evidence of that)
My guess is that smoke would appear, near instantly, from the low voltage section
My guess is that some small trace components may emit some smoke on the side of the high power section
My guess is that if it were just a few seconds... that the supply would still work... but that some parts may have a 20% tolerance now
SO
Replacing the main caps may get us back to our 1st order repair
Second order would be to have a look around at other possible damage...
Where
We want to reason about things... based on measurable evidence... using methods and ways and tests which can be repeated... so as to avoid fighting about
Who Started the war
Who has the one and only one real god
Who has right to this land and why...
So long as we continue with those sorts of disputes... the national debt will continue to climb - as will civilian casualties.
So -
If you are a holly warrior... on ANY side...
Consider for a moment how things will converge
Use a PID loop
Consider the cost of having shattered Post Traumatic Stress warriors being feed back into the feedback loop.
Consider business assholes who will manipulate you and stoke the fires for their personal profit
Consider instead of dealing with politicians... dealing with engineers... who are bound by logic and reason
ENGINEER FOR PRESIDENT
frock DONALD DUCK
No more lawyers
No more business men
No more military men
They have all had their chance
No more frocking around...
Its time to have an Engineer as president
Not a software engineer
Not a mechanical engineer
An Electrical Engineer
Or someone like Elon Musk (who admittedly is a fierce businessman... obiously... but he is bound by logic and reason thru hardware)
Do that...
And I predict
That we will see a turn for the better.
-methods
SO
Where
Who Started the war
So -
Use a PID loop
frock DONALD DUCK
No more lawyers
Do that...
And I predict
-methods
