heathyoung
<Warnings>
This produces an unisolated DC voltage that sits 200V above earth potential - both leads are deadly, your pack must be isolated from the chassis. This can kill you without even trying! You MUST have discharge resistors or you will get a belt from the pins on the power plug! Ouch!
</warnings>
Hey all - after I had yet another bms battery charger exit stage left in a spectacular fashion (sigh) I decided to knock up something to charge the 44S Lifepo4 pack on the vectrix.
I have seen a few people use very simple capacitive reactance to limit the charge current, but these don't limit the termination voltage, so can't be left unattended or very bad (tm) things happen to your battery.
So I decided to take another tangent and design one based on a reactive divider - where basically you use capacitive reactance to create a voltage divider, that has no heat loss and current limits by default!
I needed about 160ish volts, and have 240VAC 50Hz, so settled on a 100uf and 120uf capacitor combination, a bridge rectifier and a smoothing cap. This gave a current limited 165V DC @ about 450W to change with, and evolved very little heat (apart from the bridge).
The main problem with these chargers is they are highly reactive - expect a PF of no better than about 33, so you draw current spikes 3 X your charger output (ie my 450W charger was drawing 10A spikes) - the power meter in the house (which doesn't account for PF) was showing a 1400W draw - 1000W would be pushing your luck on a 16A breaker I think. Don't use it anywhere where you pay for power in KVAr, unless they use really big motors, in which case you will be doing them a favour
With no output loading, the charger simply acts as a large capacitor across the mains (ie. PF = 0) and consumes no energy (except for the discharge resistors)
Caps I used were ironically massive PFC units from a scrapped UPS, but motor run (not start) caps would work, and even polarised electrolytics run back to back may work as well (if they have bypass diodes) bearing in mind that their ESR becomes an issue.
Thought that this may be useful to someone out there, who needs a quick and dirty solution till their charger gets fixed (or they build something better)
</warnings>
