markobetti
- Joined
- Jul 16, 2009
- Messages
- 620
splint. , i found some dc converters , better check your pm , i dont know if you need this kind but link is in your mail
Were you trying to use it above the rated amps?SplinterOz said:Arlo1/Jones
We tried a laptop supply and did not work for us. I have only a 80volt pack or so and down to 76 (or lower) under load. The supply did put out the voltage but couldn't sustain the current required. Most of the AC adapters are arrange to work from 100v up to 250v AC and from what I understand they are basically a bridge rectifier then a switched mode DC/DC converter.
The other thing to to watch out for is to ensure they are isolated, that they do not share -ve between the two voltages.
Arlo1 said:Were you trying to use it above the rated amps?SplinterOz said:Arlo1/Jones
I have to do something as well for mine for the lights horn ect.
Most PC and laptop PSUs that I've seen tested for such things will work reasonably well down to ~90V, but not much below that. So yeah, your input voltage was probably just too low.SplinterOz said:We tried a laptop supply and did not work for us. I have only a 80volt pack or so and down to 76 (or lower) under load. The supply did put out the voltage but couldn't sustain the current required. Most of the AC adapters are arrange to work from 100v up to 250v AC
jonescg said:If I recall, DC/DC converters aren't very efficient. In fact, a giant 50 W resistor would probably do the same job at similar efficiency. I need to find a decent 12 V axillary for my bike too. Was thinking of a 4S2P setup with A123 cells and charge it separately with my balance charger.
Yep I am going to mod the battery pack this week to do exactly thatmarkobetti said:uf... dont pull current form battery to controller through bms ,maybe you could bypass bms .. and use it only for balancing ..
Arlo1 said:The video definatly looks like you have a promising system!
Cant wait to see more progress.
SplinterOz said:Arlo1 said:The video definatly looks like you have a promising system!
More work this week, hopefully more photo's videos before the end of the week.
I have lined up a loaner Kelly, and loaner battery if required.
markobetti said:you have few mods in kelly ; check witch one suits it best . Also , the gearing should me at least 1:4 on the bike the kv is same as agni motor kv and agni is geared 1:4 , 1: 6 it dependes . Also it would me easier for the motor testing to get him rolling more easy on low rpms .
Hey Splinter I just got my 24 fet running and I am getting controler resets.SplinterOz said:markobetti said:you have few mods in kelly ; check witch one suits it best . Also , the gearing should me at least 1:4 on the bike the kv is same as agni motor kv and agni is geared 1:4 , 1: 6 it dependes . Also it would me easier for the motor testing to get him rolling more easy on low rpms .
Gearing is currently 1:4.15 which I think is ok. I might move to 1:5 which should still give me an acceptable top speed, any thing higher than that means not being able to reach 100km/h.
I know I have to get the high speed mode for the Kelly. Once tested with the loaner I will confirm which way I go.
gwhy! said:It may be worth checking out the thread that have solved the cutting out problems with the infiron controllers it may be related with your cutting out problems.
This is about what the max is from a 24 fet that has been modded and had the traces built up ect.SplinterOz said:So it is Controller time... Now I want this to be a daily ride and it has to meet the Australian Design Regs. So I need a sealable controller with removable cables (or Orange cables attached) that can pull 150amps continuous from the battery pack peaking to 300amps.
What are people using?
