Hi everyone!
I just finished installing a BMS on a LIFEPO4 battery.
This is the first time I've installed a BMS and I think I got everything right! (Judging by no fire and good voltage on the ANT app)
I have a pack I've bought from Amazon that claims to be a 30AH 72V pack, the original BMS was 80/150 AMP bms, but it didn't charge so I got the pack for free.
The listing on Amazon said that the cells are A123 pouch cells, but when I opened the battery I've found pouch cells that I can't get any information about.
I'm not sure what the real discharge rate of the cells, so for now I'll set the controller to 80 continues and 120 peak, same continues value as the original BMS and a bit lower peak, and monitor the temp rise, would love to get your advice on how to determine how much juice I can squeeze from this pack and keeping it safe.
Now back to the subject!
The BMS I've bought is ANT 10S-24S 1.6cm thin, 120A cont 300A peak.
This is the parameters I've set / were set by default, can you please take a look and tell me if this all looks fine? I want to test it with my brand new QS138 but prefer patient over smoke.
Thanks!!
Thanks!!
