ANT BMS Problems
JT101224
New here
UK
Hi,
I have ANT H-24S 300A BMS that support 8S - 24S lion cells connected to 18S battery (3 lipos connected exactly as per the ANT BMS data sheet for 18S cell batteries) and not matter what version of the ANT BMS software that I use, I cannot seem to be able to change any settings to the parameters. I have tried setting up the passwords as have been described on earlier posts on this site, but nothing works. I have tried two separate BMS boards purchased at the same time. I can connect to them OK, it displays the cell voltages, but no values are displayed in any of the board parameters settings (although it stills displays 24 cells, as I cannot change the settings to 18S) I cannot seem to gain access to the level 5 permissions needed to change the settings, not mater what I do. My only thought now is that both boards may be faulty. Anyone have any ideas?
Try use the VBMS app shouldnt be any passwords and you need to make sure phone is connected to BMS via bluetooth and it should work. My BMS only works with this app
They keep changing protocol and when they update the app it stops working for old versions. Usually you can see the cells but you are unable to change settings.
If you have an android you can install the old version of the app. Try to see the date of your BMS or publish some photos maybe someone can tell you the correct version for the antbms that works for you. Also
Thank you . I am trying to get hold of the VBMS app. I have messaged Vortec Ebikes, who I believe developed the app, as it is no longer on Play store for android. :)
Thank you for your help - Here is a picture of my BMS...
Mate Give me PM and i can email you the APK or ill try put it on onedrive for you?
