branson.cz
i’m building a new 20s 18p battery pack, and it’s able to do 500a cont. yet i cannot find any bms that is able to do 500a cont. should i just get the ant 380/950 peak? or does anybody know of another bms
Ah, so it's a motorcycle with pedals.i’m already doing 250a lol, it’s a super73 rx with a fardriver 72530 and a qs205.
i’m trying to build a very fast bike for certain reasons. i’ve seen the jk but for the price i’d rather go with the ant 380cont 950 peak with passive balanceWhy do you want to run 500A current through the bms.
If you want big numbers go for a shunt to measure current and only let the bms control the cell voltages and a charge contactor and a discharge connector.
I'm using a JK-B2A24S20p BMS in my scooter equipped with a ND72680 running 270A and 300A boost at the moment, but after installing a 10kw hub-motor I want to go for the full 350A.
The JK-BMS can do 350A for 60seconds.
it’s a “e-bike”Ah, so it's a motorcycle with pedals.
250A continuous current draw usually means that you are going up steep hills at high speed, or going very fast against severe wind resistance.
What are your actual riding conditions, and how are you actually riding, at what speeds, etc?
If you define all those things as completely as you can, you can then find out what power it actually takes to do what you want, so you can make sure to buy the parts that will do that job for you, instead of re-buying things as you find they don't do what you want, and wasting your time and money.
If you won't do that, the best I can recommend is to get a JBD contactor-based BMS and if they don't have one with a contactor and shunt rated high enough, replace the contactor (and shunt) with ones that are, and change the BMS settings to match.
i thought my bike was slow too compared to some of the stuff on hereGeez dude, a legal issue waiting to happen with that much power.
I don't know where your vehicle belongs on this forum exactly but we're gonna move you over to motorcycle land because in ebike land, only ~0.1% are using controllers with 100A even![]()
can’t wait to join the club, i’ll 100% get in trouble for it but the cops here don’t file their tickets if your under 18 on e-bikes usuallyNo, we do have some insane bikes on here but the 500 amp club is smaller than you think.
Good luck out there.. but do let us know if you get busted!![]()
i was planning on doing 20kw for awhile until i upgrade to a qs273, or if i can find something better maybe used?? was your motor injected with statorade and did it have a hub sync?You want to feed the QS205 with 30kw? Or will you use a different motor?
I burned the awg 6 phase wires from my qs260 with 24kw in a few minutes. Now I have upgraded to 16mm² AWG5 with 205C isolation.
alot of bad financial decisions to get this much power but it’s too much damn funBoy am i glad i didn't have access to this level of power at your age!
Carry on
ah okay i have statorde on order. hopefully that helps a bitThe inside was still ok, only the phase wires burnt. No statorade or hubsinks.
