YoshiMoshi
🔋 Established
BMS ratings have a "Maximum Continuous Dishcarge" rating and a "Maximum Peak Dishcarge" ratings.
Do I need to size my nickel strips for the continuous or peak ratins? It's my understanding that the continuous rating, is the maximum current allowed by the BMS. The BMS allows for current over the continuous ratings, called "peak" in short bursts and small time intervals. I've seen testing on YouTube where as much as 9 seconds is allowed at the peak rating before the BMS cuts off the battery. Not sure if there's a standard time interval allowed by BMSs at the peak current?
Anyways the peak ratings are sometimes double the continuous rating. Should I size my nickel strip for my battery at the continuosu rating or the peak rating and why? so say for example 30 A continuous and 60 A peak from the BMS. Am I able to use cope wire rated for 36 A in this battery pack, or nickel strip rated at 32 A from Matador's table? This is greater than 30 A continuous rating, but significantly less than the 60 A peak allowed by the BMS. Is this OK?
Thanks for any help in understanding this concept!
