Just wanted to throw a line out and see if there is any interest in this.
I am working with a company that can CNC sprockets of various tooth counts that mount to disc brakes.
These sprockets can be designed with #415 ( BMX chain ), or #420 ( heavy duty trike chain, close to the width of #40 ) in mind. I will offer a few standardized sizes, such as 30T, 35T, 40T, and 50T.
I can also have a 2.5mm inward offset milled into the gear, if you need a little extra clearance on your frame to run the chain. This is helpful if your chainstays are particularly narrow, and you are running 2.0-2.3" tires. Often times, a chain drive system is a rather tight fit on some bikes, so this can help get any extra clearance that is needed.
Regular sprockets can be flipped around to adjust the offset of the gear teeth by about ~3mm.
Milled out of extremely tough aerospace grade aluminum.
Price would range from $50 to $70 shipped.
Sprockets would look similar to this.
If there is significant interest in something like this, i can get a design ready, post some pictures up of examples, and get some of these bad boys made. Raise your hand if you're interested in a product like this.
