The ZZ Thriller looks too big, particularly with the leg coverage. A smaller version of the OS ZZ, combined with aerobars to the get rider lower seems like it would be the best setup for most.
https://www.zzipper.com/Products/prod_upright.php
My two designs, the first was the ebike and the 2nd(white) was for the emoto. Both worked very well for knocking down wattage at normal riding speeds. (25-30mph for ebike), and 35mph+ for emoto. wh/mile told the story. About 70 down to 50wh/mile for the emoto.
I ended up leaving the emoto scene and the ebike is now without the fairing because I wanted to pedal more, and so that meant a normal seat position, which made the fairing look a little odd since it was designed for the low seat.
The ebike easily consumes more watts with me pedaling moderately at 25mph than it did with the fairing/low seat and no pedaling. Throw in a cold headwind, and things get real ugly for the non-faired setup. I ride a lot slower than I use to. (another benefit of the normal "high" seat is the cargo room behind me). I really do missed tucking down below my windshield of the fairing when getting hit with a cold headwind. The sense of just knowing you are the most practical and most efficient setup pretty much anywhere.
The moral of the story here is that a normal upright bike (even mtb racer position) exposed too much frontal area to allow a non ugly, unobtrusive fairing to make much of a difference. You need to go recumbent or semi recumbent at least. Though I think a small one for roadies on aerobars might give a noticeable benefit. No one has made one though. I have been thinking about it for years, but lose my focus. Roadies tend to follow the racing scene which of course won't allow any aero mods.
I think if you get a crank foward bike like the Rans Fusion, drop the handlebars a LOT, that will get close to the position I had on my ebike above, but you could still pedal. Frontal area should be low enough to allow a reasonable fairing. I've though about going this route, but rear suspension is a must on an ebike IMO. There is a semi crank forward rear suspended brand out of San Diego, but I didn't want to drop $250 on it since I don't have a sizeable commute. Also, not sure the cranks are forward enough to really get you lower. http://www.rustyspokes.com/
I've been at stores analyzing mixing bowls, thinking how I could modify one to make a cheap quick fairing.
