Aotema ATM08060786 hub motor
EmAre
🧲 New user
Victoria B.C.
I recently acquired an Aotema hub with the ID# ATM08060786. From what I have read on the forum it may be brushless, ( 3 wire connection ) and 36 volt. If anyone can confirm that it would be very helpful. The bearings seem a little stiff and rough so I’d like to take a look at those. Has anyone seen a parts diagram or exploded view that would give me an idea of the disassembly. I will try to give the motor some power when it’s mounted on a fork to see if I even have a motor. If all that goes well does anyone have a suggestion for a good controller?
Thanks for any ideas
When I read your question I started thinking "there's no such thing as a brushed hub motor"--but apparently there is:
It's probably brushless though if it has three wires.
Since you said you read on the forum, maybe you already saw those, but I thought I'd post them here anyway for reference.
Thanks, every bit helps.
Putting it on a fork? For sure not suspension I hope and just had to say that
I dont know the specific motor but imagine u can add grease/oil to the bearings without disassembling the motor and just take off the outer bearing seals to add grease or sneak a thin oil in with gravity
I’m a big fan of the 75100 vescs with Bluetooth: cheap and powerful
