Hey guys! I'm looking for higher-end road tires to replace the knobbly 20x4.0 tires that came with my ebike. I've been looking for motorbike tires, since the only road-style bike I can find in 20x4.0 size are Supermoto X, which are a bit more on the expensive side and wouldn't be as hardy as a motorbike tire. Obviously, motorbike tires are heavier, but my bike gets a good week on a charge, so I'm not too worried about slightly reduced range.
At first, I had been looking for tires mark as "110/SOMETHING-16, since that seemed to be the figure that I saw online for what size motorbike is the equivalent of a 20x4.0 bike tire. However, I've measured the width of the tires that came with my bike, and they're actually 100mm wide, 110mm would scrape against my chain!
So instead, I've been looking at tires marked as "100/SOMETHING-16". I've been having trouble finding good choices in this size, just Dunlop K330A so far. But I've also seen tires marked in inches too, and according to THIS TIRE CONVERSION CHART, for a front, road tire (all the correctly-sized tires I've found are marked as "front" so I'm assuming I need to use the front measurement) "100/90 is 3.25/3.50".
However, not quite sure how to interpret this. By "100/90" do they mean "100mm wide, 90% ratio" or "100mm = 3.25" and "90mm = 3.50"? 100mm is 3.93 inches, but I'm assuming the difference is 'cuz motorbike tires are measured by the rim and not the tire. But either way, I'm not sure how a larger measurement in mm winds up as the smaller of the two measurements in inches, so that's clearly not right.
Does anyone know how to interpret this conversion? What 16 inch motorbike tires would be roughly 100mm wide in imperial measurements?
