MadRhino said:
Punx0r said:
With high-powered motors, well, I think there's reason no one makes a front-wheel-drive motorcycle...
Well they did, but it was not a success.
On a car FWD makes some sense because one can learn and control front slipping. On 2 wheels there are very few 6th sense gifted riders who can control a front wash, and most who tried to learn ended up in a high side crash.
Having road raced motorcycles back in the '90's, crashing is something I know a bit about and loosing the frt. tire results in a face plant on the low-side. It happens so fast, there is no time for the tire to try a hook-up again, which is what happens on a high-side crash.
Fortunately, frt. wheel washouts were rare and much of the time, when the rear let's go, it can be saved.
So far in this thread, we have learned that putting a large DD motor of substantial power on a $200 bike with cappy steel forks is a bad idea, and somehow, it seems that some can draw the conclusion, that all frt motor installations are dangerous and should be avoided.
The fact is, a small low power motor works very well on the frt., with little or no adverse handling effects(some would argue, when traction is limited, it's an advantage).
Quality alloy forks, such that are found on mid-range mountain bikes for the last 15 years will easily take a > 750 peak Watt motor.
Care in installation, a torque arm and some Loctite is all that is needed.
Note; Pro road racers can slide the frt. tire at will to shorten the radius of the turn. This was pioneered by the great Freddy Spencer, he was the first to slide both tires entering a turn. The only time I could ever do it and not crash was on banked tracks. Riding a Honda RS125 GP bike on the steep banked Adams track at Riverside was great fun.
I have body problems today from frt. end washouts and what I call the "water-sking"syndrome. ï can save it, I can save it"and you don't let go-result-dis-located shoulder.
