I thought this would work with just the pull down connected to the gate.... http://ww1.microchip.com/downloads/en/DeviceDoc/22019B.pdf
SO I connect the hi gate to this the driver inverts the signal and shorts out the gate to source of the low side fets when the hi side is on. But when the hi side is off it does not try to drive the gate high because the fet driver has 2 outputs. 1 is to pull low and the other is to pull hi....
Edit no I don't think it will because I need something that doesn't turn the gate on only clamps it off. So either a source sink output or a driver that doesn't need voltage hooked to it.
