Lebowski
bigmoose said:4) I can't comment on Lubowski's algorithm on turning on the lower FETs of the H bridge. This is key to charging the upper bootstrap caps. I always have my routine do this to precharge bootstrap caps before we use them in the PWM routine.
This is why I added 'low side pulsing' as an option going into version 1.01 .. I had the same issue with the
high side bootstrap not charging properly which caused the chip to stay stuck in drive_0. What I added is
an option for low side pulsing, when turned on it will turn on the low side FETs at a (user) specified
frequency and time (I use 20 Hz and 20 usec myself). When pulsed the low side FET's will pull all three
motor outputs to ground, providing a nice clean path for the high side bootstrap caps to charge. When
properly charge the bootstrap charging current will become 0 and the motor voltages inputs of the
chip (pins 5, 7 and 8 ) will be at 2.5 V (half the 5V supply).
