# (c)opyright 2012, B.M. Putter #
# Adliswil, Switzerland #
# bmp72@hotmail.com #
# version 1.02 #
# experimental, use at your own risk #
a] calibrate hall sensors
b] determine coil positions
c) PWM parameters
d) current settings
e) control loop parameters
f) throttle setup
g) running modes
h) CAN bus setup
z) store parameters in EEPROM for motor use
------> c
a) PWM frequency: 20kHz
b) deadtime: 599ns
c) dutycycle testsignal: 50%
d) toggle high side polarity, now active HIGH
e) toggle low side polarity, now active HIGH
f) test PWM signals
z) return to main menu
------> f
PWM test signals active
Press ÿ[00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 599ns
f) test PWM signals
------> f
Press any key to deact©º×
Û÷þ[00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 599ns
f) test PWM signals
------> f
Press any key to deactivate
ȕ[00][00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 599ns
f) test PWM signals
------> f
ÿ[00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
a) PWM frequency: 0kHz
b) deadtime: 8499ns
f) test PWM signals
------> f
b) deadtime: 8499ns
f) test PWM signals
------> c
new value -> a
b) deadtime: 8499ns
c) dutycycle testsignal: 48%
f) test PWM signals
------> a
new value -> 20
b) deadtime: 8499ns
c) dutycycle testsignal: 4281%
f) test PWM signals
------> b
new value -> 500
b) deadtime: 499ns
f) test PWM signals
------> c
new value -> 500[08]
b) deadtime: 499ns
f) test PWM signals
------> f
»öÿ[00][00]ÿûþÿÿŽ|àÿ[00]ðð[00][00][00][00]ó[0E][00]ç[00][00][00][00][00][00][00][00]Àÿÿ[03][00]þÿøÿ>[00]ÿÀ[00]ÿ[00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 8499ns
f) test PWM signals
------> a
new value -> 20
b) deadtime: 8499ns
c) dutycycle testsignal: 4369%
f) test PWM signals
------> b
new value -> 500
b) deadtime: 499ns
f) test PWM signals
------> c
new value -> 50
b) deadtime: 499ns
f) test PWM signals
------> z
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
a) write variables to EEPROM
b] reverse direction and write variables to EEPROM
------> a
Data stored in EEPROM for motor use
------> z
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 499ns
f) test PWM signals
------> f
[1B]0[1C][00][00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 499ns
f) test PWM signals
------> f
Û[03][00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 499ns
f) test PWM signals
------> f
Û[03]û[00]
# version 1.02 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
b) deadtime: 499ns
f) test PWM signals
------> f
b) deadtime: 499ns
f) test PWM signals
