Hello everyone,
I have a a 250W hub motor and a 350W controller on my bike, both noname. Everything was going great until i decided to do the shunt mod (sometimes you gotta do what you gotta do). After that while the motor was under load (accelerating on a straight road) it would make that grindy/resonant noise which would result in:
Nasty resonant noise,
Loss of power,
vibrations and shakiness.
Since then i have to give it very little throttle while accelerating to avoid that.
And I also ran the motor in sensorless mode for a bit after the shunt mod (connected the 'learning' wire on the controller to make it 'learn' after removing the hall connector)
Then i plugged the hall connector back in and done the 'learning' step again, no difference.
Before the mod, while accelerating, it would do the resonant noise but it was brief and didnt result in power loss or a little amount (maybe?).
I always help my bike with pedals while accelerating from a dead stop and on inclines.
I run my dumb (non-smart) controller in sensored mode.
You can hear the godawful sound in the video. Even though Im helping it with the pedals. (Note: The hub motor is on the rear wheel, I could only put the camera in the basket in the front[if thats what its called]). I also suspect that a magnet might have fallen out of its slot and may be getting jammed somewhere, but its unlikely i suppose.
Any help would be appreciated, thanks.
Loss of power,
