Salty Souls
🔌 New-ish
Hi,
Ive recently completed the build of my new ebike and am now encountering a couple of issues:
- Hub motor noise
- Hub motor drawing high watts under no load
- Hub motor cutting out at certain point (speed)
Background
- Battery is 52v 20ah, 50A BMS (new)
- Controller KT sinewave DC 40v - 75v, 45A (new)
- Motor bafang RM - G0F4 1000w (believe this is the same as a GF062 1000w) (second hand)
Situation
- All the componenents are new to me so I dont have a baseline of noise or performance.
- The hub motor was puchased second hand and it had a hall sensor issue which I fixed (i believe). I've tested all the hall sensors with a multi meter and an ebike tester, all appears to be ok. I also tested the phase wires, etc of the hub motor, once again all appears to be ok.
Issues
Video- Noise - when accelerating with the throttle the motor is making a loud noise. The noise is louder than my other ebike and so Im just not sure if this is normal. A loud whirring noise
Video- Watts - the motor appears to be drawing in excess of 100W under no load when accelerating. I didnt think it should draw this many watts under no load. Also I wondered how accurate the KT display is with regards to Watts?
- Motor cut out - the motor cuts out at what appears to be between 20kmh to 30kmh
Ive tried the 36 different combinations of phase and hall wires configurations and this appears to be the best.
Ive also posted a picture of my current settings.
Any help / guidance would be great.
Thanks
- Hub motor noise
Background
Situation
Issues
Thanks
