Hi Li-ghtcycle,
I have just finshed reading throught your whole thread -(this time). I had flicked through it a while back but now im on the lookout for a new motor for my chopper I read it through.
My Schwinn Spoiler has a similar laid back riding postition to your bike. Not great on the butt for peddeling
As I read through your thread I got more and more interested in the motor you bought. I have already burnt out 2 Unite motors due to not gearing them - a 36V 500W (not quite burnt out but close) and a new 3 week old 36V 1000W that smoked like crazy and stopped working while doing a bench test on Sunday
Id like to do about 30mph crusing speed, so im tossed up between the Golden 800W like yours...
(better built than the Unite motors I think?)
...or this
Mars ME0201013001 Brushless DC motor, 100 cont amps 24-48v DC.
Slightly Used (<10 hours) MARS ME0201013001 Brushless DC Motor.
NOTES:
This motors fan cover is missing.
The connector on the wire from the motor has been cut off
Slight score marks to the shaft.
Other than the above it is a happy running bargain! It was removed from an electric go-kart project hence the above issues.
Designed for long life. No brush maintenance. The motor is 90% efficient at voltages between 24 to 48 VDC. Continuous current of 100 amps at 48 VDC. This is a 3-phase, Y-connected Permanent Magnet Syncronous Motor with an axial air gap.
20 turns per phase Line to Line resistance of 0.013 ohms Motor weight of 22 pounds.
I think both motors weight in around the same, 20 or so pounds, which is the killer plus I think? a controller for the Mars would be more expensive. Also the Mars maybe slightly to big to fit in the gap in front of my rear wheel.
You mentioned during your post's that you have a Lyen controller for your motor but you never mentioned what size/type/price? Was it easy (for a dummy to program/setup).
Anyway, enough of my babbling. Congrats on a neat build :wink: Your Evgrin must be a wrap around by now
Regards
Tom
