SnowDog2112
I was just out enjoying my ebike even though it was cold rather out.
Seems that the loud click coming from the rear hub or freewheel, has turned into a full slipping freewheel.
This loud click is not the normal ticking of the freewheel. My hub did it since I first tested it out...it's gets more obvious, the higher the gear you have it in.(You hear it when you pedal, and not when throttle is applied).
Tonight I got the freewheel to slip while pedaling. So I'm pretty certain it's failing / failed. I don't mind swapping this freewheel out and perhaps getting one with a higher top speed gear. I think I have a 14t now.
Will a new freewheel get me in business or do I potentially have a bad hub? Should I be getting on the horn to the distributor? my warranty may be expiring.
