Spesseh
Hi,
Biked a steep hill with heavy baggage in carrier. Suddenly the drive died and it won't turn on.
I changed the controller without helping. Measuring the battery at its terminals shows 41V. Measuring the volt between battery and drive is initially 0 once I power on the battery. Then increases slowly. When I hit the power on button for the drive the voltage drains slowly.
See video that shows this behavior (watch the multimeter):
https://www.dropbox.com/s/e0q30hmymenoz19/2017-09-08%2022.05.10.mp4?dl=0
Any idea what is going on? Burnt the drive or killed some battery cells? Suggestions?
Thank you for insight!
