Well, that explains the earlier confusion.I’m curious, how are you making these pin/wiring changes anyway?
Sounds like a waste of money unless you bypassed the damaged one as described and have full 5vdc at the controller…I've just ordered a new LCD...shipping will be 8days![]()
If he really has a Bafang canbus controller it would not work that way if his controller uses same protocol as other Bafang mid motors...Have a link? Does it also have gear, speed sensor or light plugs? For an 8fun bike?
Surely the controller’s ground goes to two pins…? Worth a recheck… Harness has both display and throttle connectors right?
That will be up to you to decide if you want to crack it open or not. But if it’s stuck on, I would not recommend it being used.
As mentioned previously, the controllers ignition circuit is powered on thru the display.
You can remove the display, and CAREFULLY jump harness display pins VCC, pin 1, ORANGE wire and P+, pin 3, BROWN wire.
This will bypass the display and power on the controller as being verified by the 5vdc controller regulated power being turned on.
My goal for bypassing the display is shown in this post for bypassing a typical UART Bafang controller…If he really has a Bafang canbus controller it would not work that way if his controller uses same protocol as other Bafang mid motors...
Roger that, a closer zoomed look helped me see… my mistake.I showed 8pin connector
This determined by using your original pinout picture in the Original Post.As mentioned previously, the controllers ignition circuit is powered on thru the display.
yes the canbus versions are totally different to start the controller and display compared to UART. So i assume the BBS in CAN version will be the same as all the other Canbus versions like M300, M400, M500 etc. regarding start procedure. i looked at Ali to find a connection diagram for BBS Canbus motor so he can compare HIS connectors coming from MOTOR. If you scrol down on that page it's needed to click "view more" to see everything.My goal for bypassing the display is shown in this post for bypassing a typical UART Bafang controller…
Troubleshooting the BBSHD / BBS02 - Electricbike.com Ebike Forum
Are you saying that the CAN bus version would be different?
Note: Of course the pinouts are different!
Jakuda87, why wasn’t the 8 pin connector shown?
In UART it was named VCC and PL (load) so like you know, in the uart display, in a way they get bridged by a mosfet or transistor when pressing the on / off button to start the display and controller. With canbus it is different. See post 32 for how the CAN startup works.Thank you for getting back with us.
So are you saying that the only difference between the two communication type systems. Is that the location of VVC and P+ pins used for bypassing are different due to the different connector styles. Or is there something more?
Please clarify…
Good eyeFor future reference, according to your pictures,
“KEY_BTN” is orange wire (to display, battery voltage).
“YB_VC” is brown wire (After controller is started, battery voltage to display).
“GND” is Black ground wire (for display, throttle and brakes).
“Break” is white signal wire from brakes.
“CANH” green and “CANL” yellow is canbus communication to display.
TPP was probably the 5 Volt for throttle and brakes if brakes with hall sensor.
“Meter Port? Or Meter Pocl?” it seems no wire in connector on pcb.
Is it sure pin 1 from the 8 pin (B8-F) cable harness connector go's to additional small board? With battery removed, did you measured that with your meter in continuity test?
Regarding the now missing 5 Volt on TPP is there next to the connector perhaps a smoked component? Difficult to see on your picture. Can you make sharper picture under more light from components around that connector.
