Hi,
I have a hub motor (for xiaomi m365) that has a cable which does not end in a julet connector.
My controller has a 9 pin female julet connector. Due to various mechanical factors on the build, it would by far be the most practical if i could convert my motor to have a 9 pin male julet connector.
(I am aware that i have to get the phase, hall etc correct and know how to do this)
Since julet connectors cannot really be DIYed due to being molded, I will make an adapter cable that is 9pin male-julet to 'something'. I will cut the cable on the motor and make it 'something' also.
Basically make this female end of this cable from controller connect to this motor in a waterproof way.
But what would you suggest for something. Is it smartest to use 9 small waterproof wire terminals, or maybe som sort of 9 pin waterproff aviation plug (a bit bulky..)?
Hope it makes sense.
Hope you have suggestions also
