I need the new Bafang DPC010 Display extension cable. They are no longer 5 pin round connectors, but a new proprietary connector. And I am not having any luck finding one here in the US.
Any suggestions, or am I forced to order from China?
If you look up "higo mini-f connector" "higo square connector" or "julet square connector" you should get hits on matching types, like this (and several similar) ebay ad:
Ebike Shaped Connector 2/3/4/5/6 Pin Cable Waterproof Connector Signal line. This is THE best option for having water tight connections on your e-bike. Julet Connector. 1 x Extension cord. RED = 2 PIN.
www.ebay.com
Most of them are probably outside the US, but you may find one that isn't.
