Bafang bbs02b crushed wires.
Bafangfink
100 µW
Hi all new to the forum and ebike motor's,I have brought a used bbs02b and the main control wire has been crushed by the swingarm, the little green wire has been severed but the rest look OK, although have been crimped a little but not snapped, can I use a tiny copper crimp connector to fix the wire or is the voltage so small that anything other than a perfect original wire will not work, I'm assuming it will, but with the wires being so fine it may not, any information would be great cheers.
Yes,
Small crimps work ~20 or 22GA ? for the low voltage and higher
Check continuity on all wires to find any damage hidden by insulation.
Good luck
Thanks for the info, thought so but a confermation is always good when it comes to electrics 👍
