Toby82
Hi Guys,
After receiving a dud crystalyte H series motor from crystalyte I decided to go back to the geared option as I have had no issues with my BMC and like the light weight and small size of the geared motors.
Not requiring a high power output I decided to go for a Bafang BPM front motor (350W) from BMS battery.
The motor is fitted into a 20" rim with a 36v 35amp controller.
The motor performed well for about 5 mins of easy riding but then began to slip internally as if the clutch is not engaging properly. When I apply a decent amount of throttle I can hear the motor spin up without much acceleration or change in speed so either the gears are stripped, unlikely due to the amount and type of use, or the clutch is not engaging properly under power.
With the motor/wheel off the ground I'm now able to hold the wheel steady and make the motor spin internally by apply some throttle.
Has anyone had or seen his problem with the BPM motor.
Cheers,
Cheers,
