Bafang M200 delimiting
headwind
🔋 Established
Australia
This info doesn't seem to be on the internet, so I thought I'd post it here.
A programming cable designed for an M500 motor also works to increase the speed limiter on a M200 motor. (They both use the house-shaped CAN connector for the display and some forum posts etc hinted that it might work, so I rolled the dice to buy a cable and it paid off!)
The method I used was a cheap 3rd-party programming cable from AliExpress:
This cable includes a physical button to increase the speed limit, so no computer was needed.
The instructions that came with it weren't much help, so here's what worked for me. Disclaimer: if it bricks your bike, it's not my fault! eg I had a scary moment where the motor wasn't working, thankfully when I re-did the process slightly differently it started working again
*With the bike turned off, unplug the CAN connector that's up at the display (there's no need to open the cover for the motor at any stage)
*Plug the programming cable into both ends of this connector
*Connect the programming cable to a USB power source. I used a power bank, so that there wouldn't be the complication of it trying to communicate with a computer etc. The red light on the programming cable should blink slowly.
*Turn on the Bafang display. The green light on the programming cable should blink quickly.
*Wait 10 seconds (perhaps it's just superstition, but this is what I did)
*On the programming cable, press the button the number of times required for your wheel size (once for 29" wheels)
*Wait 30 seconds
*On the Bafang display, enter the service menu (simultaneously press "+" and "-"). Go to Information then Speed Limit, it should now say 60km/h!
*Turn off the Bafang display
*Remove the programming cable and reconnect the bike's display cable
Hope this helps.
*Wait 30 seconds
Hope this helps.
Thats awesome. What is the maximum speed you are able to attain now on your bike? Is your ebike PAS only or PAS with throttle? My ebike (m200 mid motor with CANBUS) has a max 32km/hr Pedal assist (PAS only, 5 levels, no throttle). It appears the firmware is locked as Im not able to adjust any settings. Hoping to increase max assist to 35/40km/hr. Was hoping to do this with just a new canbus display (ekd01 or B02N/EB02) but cant find any concrete info that they can interact with the motors controller to actually increase max speed.
