drewdiller
- Joined
- Nov 5, 2009
- Messages
- 172
This should be short. Just checking that I understand. The reason for (very well built) multiple-belt-and-gear reduction systems I see in this forum are because:
1) RC engines are way more powerful and light compared to a hub motor, but only if you can get the motor up to the intended very high RPM.
2) To get a usable RPM to the wheel, you have to submit the initial motor RPM to multiple forms of reduction.
3) Using a gearbox for one (or more) stage(s) of RPM reduction is less efficient than a belt drive.
Specifically part 3. Is that a fair statement?
Looking to eventually get a recumpence unit when I can afford to spend moneys on non necessities again, but also weighing my options. After having ridden my first e-bike (250W hub motor), I want:
- 20mph or more (possible on 36V * 20A?)
- Much higher torque for hills and choppy snow
- Less worry about having to watch the CA for running the motor over described wattage
- Less weight, and better distribution of it
